TwinTurbo.NET: Nissan 300ZX forum - Re: Or if you are daring, with engine warm, use a folded piece
infoschumi
on November 13, 2018 at 11:30 AM
posted by mrchips
on November 12, 2018 at 10:17 PM
I can only spin it like 1/3 turn when cold and the same when engine is hot.Also,when I turn the engine off,the fan stops almost instantly.I tried to stop the clutch after warming up but it was impossible,I even left marks on the fan from trying.
Overheating
infoschumi
18:50:32 11/10/18
What method was used to get the actual temperature
jzack
17:59:53 11/11/18
Re: What method was used to get the actual temperature
infoschumi
11:24:08 11/12/18
Actually what I was getting at - how are you certain of
jzack
18:24:04 11/12/18
Sounds like it's time for an update .....
zx299
19:32:12 11/11/18
This link might be worth looking over too?
jzack
09:01:23 11/12/18
Re: This link might be worth looking over too?
infoschumi
11:28:26 11/12/18
My stock gauge has performed like your's for years (even
SirpriZ
13:24:04 11/12/18
I had a similar overheating issue, ended up being the clutch
SkiFly01
15:41:04 11/12/18
Get the car to operating temp (turn it off) and spin by hand
-Grimm-
17:07:20 11/12/18
mrchips
22:17:50 11/12/18
Re: Or if you are daring, with engine warm, use a folded piece -
infoschumi
11:30:26 11/13/18
Well that sounds wrong
-Grimm-
12:36:20 11/13/18
Re: Well that sounds wrong
infoschumi
05:44:39 11/14/18
infoschumi
05:49:03 11/14/18
A simple check that has worked for me even if rad was>>
ZUL8TR
05:14:38 11/13/18
Re: A simple check that has worked for me even if rad was>>
infoschumi
11:34:49 11/13/18
Front side of rad has the AC condenser so might be >.
ZUL8TR
03:02:11 11/14/18
Just a long shot to check — verify the AT cooler isn’t
jzack
23:06:44 11/14/18
Re: Just a long shot to check — verify the AT cooler isn’t
MightyAA
13:31:19 11/21/18
Re: Re: Just a long shot to check — verify the AT cooler isn’t
infoschumi
17:31:25 11/23/18
Re: Re: Re: Just a long shot to check — verify the AT cooler isn’t
infoschumi
15:43:51 12/05/18
